| Posted by Jo on March 06, 2003 at 10:50:15: | |
| In response to Re: Vibrating pipes | |
I went into the tank and noticed the tube with the open end was tight to the bottom. I adjusted it so that it was pointing away from bottom. When I flushed there were air bubbles which appeared and no vibration. Hopefully this will do the trick, if not I will follow your instruction. Thanks!
| There are none. |
