Re: forced hot water boiler / presure problem
Posted by Bruce on March 06, 2003 at 05:52:12:
In response to Re: forced hot water boiler / presure problem
: I have a closed forced hot water boiler. i recently bled the radiators. but no water came though.
: i realized the main cold water supply valve was closed, so i opened it and bled them again. no problem, the water flowed,
: air was gone, and i thought all was well. but now i notice that when the burner is on, and heating the water in the boiler, the pressure
: slowly climbs and hits 30psi, and the pressure relief valve lets it out. even when the system is off, the pressure is steady aound 20 psi,
: when it should be 12. do i have to adjust the pressure reducing valve? or, is it possible that i somehow waterlogged the expansion tank,
: so there is too much pressure regardless? if so, how do i relieve the tank, just let water out of it?
: thanks!
: Evan
The pressure reducing/boiler feed valve should be replaced along with the expansion tank and the relief valve
Replies to this post
