| Posted by Mark on March 05, 2003 at 20:47:08: | |
| In response to Re: water level drops after filling | |
You might need to replace the flapper inside the tank. Water is most probably seeping thru the flapper and flush valve. Does it trigger the water filling device??? Do you hear a "swoosh" at constant intervals??? If indeed your toilet is old, this might be the time to replace the entire unit... |
