| Posted by hj on March 04, 2003 at 22:49:29: | |
| In response to Re: building a tiled tub | |
My suggestion would be to forget it because the tub is going to be cold and uncomfortable. But if you insist, you use the same drain as the shower, but put a "roman tub" cover on it which has a lift and turn plug on it. : I built my shower. Now I am remodeling my other bathroom and I want to build a tiled tub. I need to know what drain to use,there is nothing at the local home improvement stores that looks right. They have shower drains but that won't alow me to plug the drain and fill the tub. I plan to line the tub with cpu as I did the shower. The tub drains are made to attatch to a tub, but not a tiled tub.Has anyone built a tiled tub? What would you suggest?
| There are none. |
