| Posted by Chris Merkel on March 04, 2003 at 08:15:40: | |
| In response to Re: Glenwall Wall Mount Toilet Installation | |
![]() Thank you for you help. These "backing nuts" - are you saying that I just screw the nuts into place, so they are flush w/ the wall, then my toilet backs up to these nuts? I assume these are just the nuts that came w/ my carrier. Also, I need to find a replacement neoprene seal, but am having a hard time locating one. Any insight into where I can find one? I've tried the common retail places (home depot, lowes, etc), but I imagine that I'll have to go to a full blown retail plumbing supply.
: : I'm installing the (Glenwall) American Standard Wall mount toilet and am seeking some advise when doing the final stages. I already have my closet carrier installed (Zurn Z1212), w/ my waste flange out 5/16th inch and my four support bolts out 2 1/8" each {both dimension are outside of the finished wall}. : : My wall carrier came with a neoprene seal, which mounts onto the back of the toilet, then butts up to the waste flange/horn. : : Question(s): Do I just continue to mount this directly to the wall. When doing so, it seems as though there is still more "wiggle room" than I care to have. How can I make this more secure? Also, how tight should I tighten the mounting bolts? (I assume just past hand tight). : : Wall mount toilets are more common in a commercial application, so I can't find much documentation on the do's and don'ts for these residential types. : : Any insight is appreciated. : : Thank you.
| There are none. |
