Re: Glenwall Wall Mount Toilet Installation
Posted by HJ on March 03, 2003 at 23:58:12:
In response to Re: Glenwall Wall Mount Toilet Installation
You do not mount it "to the wall". You install backing nuts on the two bottom bolts and the upper left one. The nuts should be flush with the finished wall. Then you place washers on the bolts and tighten the cap nuts on the two lower bolts and the upper left one. The upper right cap nut is tighten just to the point where it touches the bowl. All the cap nuts should have the "paper" washers under them.
: I'm installing the (Glenwall) American Standard Wall mount toilet and am seeking some advise when doing the final stages. I already have my closet carrier installed (Zurn Z1212), w/ my waste flange out 5/16th inch and my four support bolts out 2 1/8" each {both dimesion are outside of the finished wall}.
: My wall carrier came with a neoprene seal, which mounts onto the back of the toilet, then butts up to the waste flang/horn.
: Question(s): Do I just continue to mount this directly to the wall. When doing so, it seems as though there is still more "wiggle room" than I care to have. How can I make this more secure? Also, how tight should I tighten the mounting bolts? (I assume just past hand tight).
: Wall mount toilets are more common in a commercial application, so I can't find much documentation on the do's and don'ts for these residential types.
: Any insight is appreciated.
: Thank you.
Replies to this post
There are none.
