| Posted by John Scates on March 02, 2003 at 23:47:28: | |
| In response to Re: Air in hot water line | |
My guess is that it could be something as simple as "winter time". More air can dissolve in cold water than warm, and the colder climate may be resulting in a higher residual gas content in your water supply originating at the water treatment plant. - John : You are correct, the "air" does not have an odor. Would have something have changed in the last few months to cause this? I found it strange that for the first 10 months we lived here the water worked perfectly and only during the last 2 months we have had this issue where air is in the hot water line. Thanks for your help. : : One peculiar thing about air solubility in water - unlike most solids, hot water can dissolve less air at higher temperatures. Your water supply may have a high air content that is being driven out by the heat. If this is the case, you probably cannot do anything about it. : : I assume that the "air" has no odor. The only active component in the hot water system that is unique from the cold side is the anode rod in the hot water heater. There are also some reactions that can occur with the anode rods that can add gas to the hot water. : : - John : : : We have been living in our house for 1 year now. About two months ago we started getting air in our hot water line. This only happens for the hot water. The cold water works fine. The water sputters once in a while and seems to be getting more noticeable as time passes. We also did not notice this at all for the first 10 months. Any idea what could be causing this?
| There are none. |
