| Posted by Gary Swart on February 26, 2003 at 11:03:39: | |
| In response to Re: Slow bathtub drain | |
You can try as much of the drain cleaner as you want, but at this point I'm guessing that the drain will have to be snaked. You might have success with a DIY snake since the clog appears localized to the tub drain. Another approach would be to remove the trap. That's probably where the clog is located. |
