Re: Frozen Hot Water Shut off Valve
Posted by hj on February 26, 2003 at 07:56:30:
In response to Re: Frozen Hot Water Shut off Valve
Yes, it is called "replace the valve". : It began as a search for a water leak and led to the sink spray hose. The end that connects to the faucet under the sink. : Since it is almost impossible to reach into the area to disconnect the spray hose, i figured that I would remove the entire faucet from the sink and check out the other connections. : Shutting off the cold water (Brass Craft Valve)was easy but when I tried to turn the hot water valve, it didn't budge. I tapped around it thinking I could jar the mineral deposit loose. No dice. And I am fearful to bear down on the valve since it is in-line with the copper tubing. : Is there a method or chemical that could get me out of this situation?
Replies to this post
There are none. |
