Re: Clothes Washer Hot Water Faucet Replacement
Posted by Gary Swart on February 24, 2003 at 12:19:37:
In response to Re: Clothes Washer Hot Water Faucet Replacement
You'll have to make an access hole. In the wall to get a wrench on the pipe. But you really knew that, didn't you? If the wall is sheetrock, it will be fairly simple to patch, just cut it out between the studs, then trim it back so that half the stud is exposed. The patch can be nailed on the half that is exposed.
Replies to this post
There are none.
