| Posted by John R on February 20, 2003 at 19:41:41: | |
| In response to Re: Replacing Closet Flange | |
The Wellworth flushes great! You should have seen my previous 1.6 gal toilet. It was HORRIBLE. The main problem with the flange is that the top plastic plices that but up against the metal part is crack and I had to pull off over 1/2 of the raidus of the black plastic. Also, the entire metal flange is all bent up and about 1/4 inch lower on the left than the right. I intend to reconstruct the subfloor eventually, so how do i get the plastic flange OFF of the drain pipe? Is this possible? John
: John, : On the flange repair, you can add a "red ring" over the existing flange.
