| Posted by JeffTino on February 20, 2003 at 19:32:03: | |
| In response to Re: another toilet flange question | |
Seems like I have a lot of "makeshift" plumbing in this house I bought a year ago! Does "makeshift" mean it won't work or not last? I have two drain lines I can think off the top of my head that are PVC to cast iron. I'm a electrician and maybe I should stick to wires but I like to do things myself. Attempting this situation, am I being realistic? Or should I call a plumber? Anyone? Jeff : : I have a cast iron drain system that has a lead "collar" the last 6 inches or so directly underneath the toilet. I removed the toilet to replace the floor. The toilet was bolted to a plastic adapter flange which was inserted into the lead collar. How do I go about replacing the flange for a new toilet with the lead material very much abused? : : I've had advice on cutting the lead down to the brass insert (appears to be part of the lead?) and use a no-hub connection and PVC to a new flange. What would you recommend? Thanks, : : Jeff
