| Posted by JeffTino on February 19, 2003 at 23:06:05: | |
I have a cast iron drain system that has a lead "collar" the last 6 inches or so directly underneath the toilet. I removed the toilet to replace the floor. The toilet was bolted to a plastic adapter flange which was inserted into the lead collar. How do I go about replacing the flange for a new toilet with the lead material very much abused? I've had advice on cutting the lead down to the brass insert (appears to be part of the lead?) and use a no-hub connection and PVC to a new flange. What would you recommend? Thanks, Jeff |
