| Posted by Hube on February 19, 2003 at 18:04:18: | |
| In response to Re: Toilet bowl losing water | |
: Just how low does the water go? Is it dropping low enough to let air by? Does it seem to drop when you use another water source, another toilet, take a shower, etc.? You may have a problem with a clogged vent. Without proper venting, water running down the drain can create a suction as it passes other fixtures and suck their traps down or dry. : - John : : We are have a septic system if that matters. : : Thanks in advance for any help.
| There are none. |
