| Posted by Mark Thomas on February 15, 2003 at 12:56:03: | |
I have a delta shower mix valve that has been working for 10 years but suddenly there is no flow of hot water. I've cycled the stops on the hot water side with the ball attched to handle removed but still no luck. Would the mix valve be the only culprit or could it be something prior to valve? Can the mixer valve be replaced without soldering? |
| There are none. |
