| Posted by tada on February 14, 2003 at 11:38:32: | |
I just leak tested my new tub and I have a question. I lost about 1/8" per hour through the drain. The drain is lever type and has a plunger that blocks the drain at the drain/everflow tee, instead of using a stopper in the drain itself. Is this a normal amount of leakage through the drain, or do I need to readjust it? Your help is appreciated. Tom |
