| Posted by Rob on February 14, 2003 at 06:44:24: | |
| In response to Re: Copper Pipes Running Along Joists | |
Thanks for advice. A real quick follow up. Is there a minimum spacing that should be maintained between copper pipes running next to each other? Thanks Rob
: : Is there a reason you shouldn't run copper lines against a joists? In plumbing books I've seen, they always use blocks between joists. : : Thanks : : Rob
