The seal at the stem is loose. Depending on what kind it is you may just have to tighten the nut to compress the packing. If it does not have a nut then the seal may be internal and the stem is bad. It should have nothing do with any leak inside the wall. : We were getting a steady drip from the shower-head. : Even when twisting both faucets hard-shut, there was : a constant drip. : The house is about 30 years old, with : original equipment in the shower. : I went to the hardware store, and described problem. : The guy in the store suggested replacing cold & hot : faucet stems, and seats. He thought my old seats : were scarred, causing incomplete water shut off. : I bought new stems, handles, : seats, stem extraction tool, and seat wrench. I also : bought a new shower arm and shower head and thread : tape. I went home, extracted old gear, and installed : new gear. : I no longer have water drips when faucets are shut, : and I think he was right, that replacing the seats : fixed that problem. : But, now I am getting leaks both at shower head : and at faucets whenever I open either hot or cold tap. : Here are the symptoms: : When I remove the shower head, so : that water runs freely out of shower arm, I get some : slow dripping coming out of hot water faucet handle. : When I remove that handle, the water is coming : out of the stem. : When I then replace the shower head (it's a fancy : new massage-head unit), having carefully wrapped : teflon tape around the arm threads first, I : get some water dripping out of that joint. However, : I get a lot (!) of water coming out of the hot : water faucet stem, and also some water dripping : out of cold water stem. Apparently the increased : water pressure in the system due to water being : forced out of shower head is exposing the leaking : more obviously. : I'm thinking maybe the seal between shower arm : and the water main behind the tiles isn't good, though : I did carefully teflon-tape that threading too, and : hand tightened arm as far as I could. : I'm at a loss. New seats, new washers, new stems, : new handles, new shower head, new shower arm, : new teflon tape, but drip drip drip. HELP!!
