corner shower enclosure adjustment
Posted by Greg Lewis on February 11, 2003 at 11:39:17:
I have just purchased a house with a glass corner shower stall. It is three-sided with a left-handed swing out door on the flat front. Somehow, the door and the enclosure walls have worked loose from the pan. The door hangs up at the bottom and makes the whole frame shift and move out at the bottom. This leads to the caulk breaking and water leaking out the front. How do I tighten up the enclosure walls to the pan. I have no information on the manufacturer. And how do you adjust the door. Thanks for any help.
Replies to this post
There are none. |
