| Posted by Lonnytheplumber on February 11, 2003 at 00:41:30: | |
| In response to Re: Sealing closet flange hub to slab soil pipe stub without welding the joint with PVC cement | |
: I am about to install a hub-style closet flange to the 3" PVC soil pipe stubbed out of a concrete slab. : As owner/builder I am reluctant to permanently weld the flange hub to the stub with conventional PVC : cement as it would be near-impossible to replace the flange in the future without breaking the stub. : Moreover, there is a subfloor built over the slab on sleepers topped with substrate and tile making access : to the stub area impossible without major floor surgery! : QUESTION: Would a reliable seal against waste water and sewer gas be obtained by applying a : Replys will be very much appreciated. Glue the flange. You will get stink even if you don't get a water leak. We seldom replace a plastic flange unless it has a metal slip ring.
| There are none. |
