Re: Removing pop-up tub stopper
Posted by tada on February 10, 2003 at 16:12:59:
In response to Re: Removing pop-up tub stopper
I don't remember exactly how the drain cover attached, but you can go to Home Depot or Lowe's and see this type of drain. From there you can see how it goes together, or ask for more help. : My neighbor�s bathtub has a spring-loaded pop-up stopper that he wants to remove temporarily to help clear a clog. Unfortunately, I can�t see how to get this stopper out. There doesn�t seem to be any visible setscrew or retaining clip but it is firmly attached. Trying to unscrew it doesn�t work - the stopper just spins on the stubby rod that connects it to the drain assembly. By the way, there is no lever mechanism that operates this pop-up � I just operates by pushing the stopper down or pulling it up. Any ideas?
Replies to this post
There are none. |
