| Posted by hj on February 10, 2003 at 16:12:21: | |
| In response to Re: Pressure Reducing Valve | |
The pressure reducing valve is not working properly, but the diaphragm is not punctured or water would be leaking out the top of it. : I have a pressure reducing valve in my incoming water line and have set it to 55 psi when the water is flowing. After I stop the flow pressure builds to 80 psi over a period of about 60 seconds, with the hot water heater off. Does this mean the pressure reducing valve is leaking through? If so, is it caused by a faulty seat or is the diaphragm ruptured?
| There are none. |
