| Posted by hj on February 10, 2003 at 08:22:05: | |
| In response to Re: Closet flange removal | |
I have removed many of them, but it takes time and experience. You will probably damage the pipe if you try to remove it. : Novice plumber, I need to remove an old plastic closet flange. What is the best way to loosen the glue to remove the old flange or does it need tobe chiseled out?
| There are none. |
