Re: Sealing closet flange hub to slab soil pipe stub without welding the joint with PVC cement
Posted by Gary Swart on February 09, 2003 at 23:43:59:
In response to Re: Sealing closet flange hub to slab soil pipe stub without welding the joint with PVC cement
I'm not an authority on this, but I seriously doubt that your idea would be acceptable. I think you must glue the PVC and, if necessary to replace it in the future, you would have to break concrete out. If I'm unaware of something else that would work and be acceptable to code, I'm sure some of the real pros that are usually around here will set us both straight.
Replies to this post
There are none. |
