Drain & oveflow on jetted tub
Posted by tada on February 09, 2003 at 20:32:04:
I'm installing a Newport Brass brass drain and overflow tube on a new jetted tub and I keep getting a "weeping" at the brass to brass joint where the drain meets the drain tube. I've gone to my home improvement store and they sold me some joint sealant with teflon and I tried that, but I still have the weeping problem. I've check the drain to tub joint (silicone II under the brass drain piece, then the tub, then a rubber gasket, then the brass drain) and I find no leak. At this point, should I just go try a new drain/overflow kit? Should I stay with brass or go to PVC? Your help would be greatly appreciated. Thank you. Tom
Replies to this post
There are none. |
