| Posted by Matt PDX on February 09, 2003 at 18:18:53: | |
| In response to Re: Cast Iron Hub Fitting with 3.12 ID Hub | |
: : My problem began after I removed a section of 2 inch galvanized drain pipe from a cast iron fitting (which is set in concrete in my basement floor). The joint was originally sealed with lead and oakum. When I went to install a new section of ABS pipe with a Fernco 2x2 donut seal I found out that the ID of the hub was to big. It has an ID of 3.12 inches instead of about 2.75 inches which it looks like seal would need to have a tight fit. My question is whether or not there are seals available for a hub with an ID of 3.12 inches? or will I have to re-do the seal with lead and oakum? Note the house was built in 1941. : Matt, Have the same problem. With ABS pipe in the fernco, the fernco does not even make full contact with the hub, mcuh less seal. It is as if the fernco is the wrong size. Would like to know how you got the fernco over a coupler. Thanks, |
| There are none. |
