Re: Toilet flushing problems
Posted by Mike Wenger on February 07, 2003 at 14:55:41:
In response to Re: Toilet flushing problems
The toilet could be suffering from mineral buildup in the trap. You can remove all possible water from the bowl with a plunger and wet vac. Then use a funnel to pour about 1/2 gallon of Muriatic acid into the toilet overflow in the tank (WEAR EYE PROTECTION AND RUBBER GLOVES) Let the muriatic stand for twenty minutes in the bowl (leave a window open and the fan on with the door closed). Then flush a couple times. It will amaze you and should work like new.
Replies to this post
There are none.
