Re: Tankless water heater
Posted by Mike Wenger on February 07, 2003 at 14:27:52:
In response to Re: Tankless water heater
Make very certain that you have an electrical service and panel to support the load of an instantaneous electric water heater (see a manufacturer for requirements). The electrical requirement is very substantial. Also verify that there is no possibility of scalding under very low flow rates, as most instantaneous water heaters (my experience is with gas)control flow to control temperature. Gas instantaneous heaters typically require at least a 6" diameter flue pipe because they will be nearly 120,000 BTU. Check the Paloma brand.
Replies to this post
There are none.
