| Posted by hj on February 06, 2003 at 08:25:28: | |
| In response to Re: Odd Toilet "Double Flush", Clogged Drain Pipe? | |
If it is a newer toilet that has a replacement flapper that is "normal" and depending on the toilet bowl and water level in the tank, it will sometimes flush three times. The only time it would be due to a stoppage is if it filled up and then the water was "sucked out" when the water went down. : My toilet will flush twice and I'm trying to figure out what might be going on. Basically the bowl empities once and then, as the water from the tank continues to enter the bowl, the bowl fills and empties again. : My impression is that the drain pipe can't handle all the water at once and this is preventing a continuous drain of the bowl. : Does that theory make sense? If so, should I try to clear the drain with a chemical clog remover? : Thanks, : Bob
