| Posted by Lonny the Plumber on February 03, 2003 at 22:21:01: | |
| In response to Re: New Sewer-Line | |
: You can't answer any of the questions until you find out what kind of pipe you have. But if 40 feet has collapsed, I would not be too confident of the other 30. Pipe just doesn't work like that. : : I am about to replace 40 feet of sewerline at my house. My sewer line is 70 feet long. I have cast iron pipe in my line and the last 40 feet has collasped. What do I use to cut that pipe from the good pipe.....A Sawzall?Hacksaw?...what do I connect the new pipe with?How do I connect thy e new pipe to the city? It is unusual for cast iron to collapse. However we cut it with a metal sawsall blade. Some use 14 teeth per inch other use 18. A special grit blade is available in some areas. A side gringer will cut the pipe. You can rent snap cutters or ratchet cutters from rental stores. |
| There are none. |
