Removing old single-handle shower faucet-help!
Posted by bthart on February 02, 2003 at 16:54:27:
Howdy. Just moved into an older house. The shower has a single-handle faucet that you turn counter-clockwise to turn on and adjust the temperature. When turned all the way to hot, the water was only luke-warm. A friend suggested that I remove the trim and look for a hot-water limit switch. So I did, but didn't find one. After removing everything I can figure out how to remove, I'm down to what looks like the body of the faucet with a hex head fitting around the stem. I've tried unscrewing the body, but it won't budge. Any hints on how to get this out? Should I take it out? Once I get it out, will I be able to put something new in without ripping in to the drywall behind the shower? The faucet is hard to describe... I can e.mail pictures if it would be helpful... I'm at bthart@yahoo.com. Thanks! Brian
