reducing the noise from plastic drain pipes -Where find Barrierwrap
Posted by Rick Kraft on January 28, 2003 at 22:48:53:
I search you archives for reducing the noise from plastic drain pipes and found the following[see below].
My question is where can I find this product-Barrierwrap in St. Paul, Minnesota?
Thanks
Rick K
"We have a product called Barrierwrap that has been designed to lagg waste pipes. It can give up to a 20 dBA reduction on 100mm uPVC waste pipes. It has a mass loaded barrier to reduce the transmission of noise from the pipe unlike Armaflex. Which is only a type of closed cell foam used for thermal insulation."
Replies to this post
There are none.
