Honeywell aquastat adjustment
Posted by Don Solari on January 28, 2003 at 19:13:24:
I have a Honeywell triple aquastat relay type L8124A. I have installed a Amtrol hot water tank and no longer use the boiler for domestic hot water. Since the installation i have been getting short starting cycles on the furnance. The furnance will kick on for 15 or 20 seconds and then shut off. I would like to jump out the low setting on the aquastat to see if this will due away with the short cycles. Can this be done? If yes, what is the procedure. Thanks.
Replies to this post
There are none. |
