| Posted by hj on January 28, 2003 at 11:01:40: | |
| In response to Re: RE: Toilet Flange PVC | |
I did not notice that you had not already have the flange installed. In that case, you can cut it off, but I would suggest using a flange with a metal ring instead. The one piece flanges have a tendency to warp and then break at the points where the bolts attach to it. : I have a 1 piece toilet flange that if attached, ie (set onto the pipe sticking out of the floor), would be about 3/8 too high, thus the flange would be sitting off the floor. There is no way to lower the pipe elbow, and the riser if you will is already short enough in relation to the elbow. I plan to cut a small slice off the bottom of the 1 piece flange to make it fit and sit flush on the floor, is this ok to do?
