| Posted by Ray on January 28, 2003 at 09:48:56: | |
| In response to Re: Angle Valve Problems | |
:The brass sleeve wouldn't go far enough inside the existing nut to allow the valve to screw on. I couldn't match the threads up. I also think the existing pipe is too short for me to cut the end off and start over with a new nut. Is it time to call a plumber?
: : I just replaced an angle valve and supply line to my toilet. (The pipe from the wall is copper tubing.) The valve comes with a brass compression sleeve that is supposed to go over the copper pipe (and inside the valve when screwed down on the nut.) Unfortunately, I could not insert the brass sleeve in far enough to allow the valve to be screwed on, so instead, to prevent leaks, I inserted a rubber o-ring inside the valve, and this seems to work. Is there any danger in using the o-ring instead of the brass sleeve? Thanks.
