| Posted by Casman on January 28, 2003 at 09:38:02: | |
I have a 1 piece toilet flange that if attached, ie (set onto the pipe sticking out of the floor), would be about 3/8 too high, thus the flange would be sitting off the floor. There is no way to lower the pipe elbow, and the riser if you will is already short enough in relation to the elbow. I plan to cut a small slice off the bottom of the 1 piece flange to make it fit and sit flush on the floor, is this ok to do? |
