I just replaced an angle valve and supply line to my toilet. (The pipe from the wall is copper tubing.) The valve comes with a brass compression sleeve that is supposed to go over the copper pipe (and inside the valve when screwed down on the nut.) Unfortunately, I could not insert the brass sleeve in far enough to allow the valve to be screwed on, so instead, to prevent leaks, I inserted a rubber o-ring inside the valve, and this seems to work. Is there any danger in using the o-ring instead of the brass sleeve? Thanks.
