| Posted by dk on January 27, 2003 at 15:34:03: | |
| In response to Re: Basement Floor Drain | |
Does your discharge hose drain into a tub, into a pipe, or directly on the floor near the floor drain? My discharge empties into a tub, which then drains into a vertical pipe/air vent next to a floor drain. The water will rise slightly from the floor drain, but then quickly recedes. If your draining directly on the floor, try one of the other two options; the hose->tub option might work better. |
| There are none. |
