| Posted by Denny Kuhn on January 24, 2003 at 19:16:58: | |
| In response to Re: submersible pump problem | |
: : Several days ago, I replaced the submersible pump in my well. For a two or three days the water in the house was fine, but has turned very muddy. When pulling out and putting the new pump back down in the casing, it came out and went back easily, not catching on anything. Any suggestions? Thank you : What size pump did you replace; gpm and hp? : What size is the new pump; gpm and hp? : Did you replace the tubing? : Did you install a torque arrestor? : Are you sure it's mud and not iron? It is a three quarter horse pump, the same as the one I took out. I didn't replace the tubing. I installed the same torque arrestor as was on the old one. I am sure it is mud, and alot of it. Thanks for your help |
