Re: copper fittimgs
Posted by TB on January 22, 2003 at 13:20:09:
In response to Re: copper fittimgs
Don't know why you would need a circulator pump for hot water. In any case, hook the two water heaters in serial. The cold goes into the first heater, then out comes hot to the second heater, and out comes hot from the second heater. You can turn off the first heater in the summer if you don't need as much hot water.
: : There is only one way to sweat copper. What type of circulator? Domestic hot water or heating installation?
: : : would like to know the best way to sweat copperand where the cir. pump needs to be located
: : : thanks robert
: domestic hot water, i have two hot water heaters to hook up together thanks robert
Replies to this post
There are none.
