| Posted by hj on January 21, 2003 at 22:22:20: | |
| In response to Re: leaking water heater | |
If it was installed properly there is a valve on the cold water inlet to it. Shut that off. : HI, I just discovered my water heater is leaking and the water is seeping into the walls.Is there any way to shut the water heater off without shutting off the water for the whole house?If there is can it be turned back on when it is needed, until I get a new one.
| There are none. |
