Shower Drain
Posted by Joe Thornton on January 19, 2003 at 17:08:00:
Terry; I have a shower drain with a broken cover or strainer. The cover has two screws on either side and one screw has rusted off. My question is do you think I can remove/replace the entire drain sleeve? Does is screw down on the plasitc pipe inside or do you think it is probably glued on? The house is about 12 years old with PVC drains. Also the cover is unusual as it is about 3ins. Thanks
Replies to this post
There are none.
