Re: Leak between two figerglass showers
Posted by jeff hiatt on January 19, 2003 at 16:18:44:
In response to Re: Leak between two figerglass showers
Thanks. I had expected the reply concerning figerglass repair. Hadnt thought of just elarging the hole to expose the valve stems. That would be doable and relatively easy. The front cover for the shower handle is large enough that nonthing would show and no repair would be necessary.
Will try that. Thanks very much.
: The leak has to be in a value assembly. There is no water to the shower head when the valves are off. As far a repairing fiberglass, it is technically possible, but it would probably cost more than a new shower stall plus it may or may not look as good as you'd like. This might be the time to look at a bathroom remodel.
Replies to this post
There are none.
