| Posted by John on January 19, 2003 at 10:29:19: | |
| In response to Thanks Gary... I have one more question about pipe size | |
The waste pipe from the toilet is 3" pvc then it goes into the 4" main cast iron line. Is there any reason why you would use the 3" from the toilet? Does it really matter? : I'd install the flange that fits over the drain pipe. Then drill through the concrete and screw into the plywood to anchor the flange to the floor, or you could just drill into the concrete and use lead ferrels to screw into. Either way, the flange should be anchored to the floor. Ferncos are great for their intended purpose, but not to be the sole holder of a toilet.
