| Posted by M F Manci on January 18, 2003 at 23:10:34: | |
| In response to Re: tub drain plug | |
: I jammed a screwdriver into the drain to hold the pop up while I tried to use the pliers to remove the knob on top. I could only turn it about half a turn before I gave up. Any other suggestions? : There are several different types of drains, but if yours is the lift up style then use a pair of pliers to remove the small knob on the top of it and then a screwdriver to unscrew the drain plug itself. : : I need to clean the hair out of my tub drain and I don't know how to get the drain plug out. The last time I had a plumber here, he showed me how and as I remember, it was easy. Now I can't get it out.
| There are none. |
