| Posted by Paul W on January 14, 2003 at 12:18:55: | |
| In response to Re: high water bill?! | |
Trapper, Sounds like you probably have high utility bills other that water if the hot water is involved. Would suspect you have a leak somewhere after the water heater, if you are on a slab it is probably under the floor. From what you said that the neighbor was aware there was a problem, you would suspect that the seller did not disclose everything they knew was wrong with the house. My first call would be to a plumber, the second to the broker who sold the house. I would suspect that the state you live in has disclosure laws.
| There are none. |
