Shower leaking under Drain Flange
Posted by Bob Louis on January 14, 2003 at 11:22:48:
I have a tiled Shower floor and recently disovered by taking down damaged ceiling board under the shower floor, that water was slowly seeping from the shower and leaking from under the drain flange. I was able to find that moisture from the shower walls was seeping into loose grout joints along the bottom edges of two of the walls and making its way toward the drain. How is it possible that water is going under the drain and leaking out? Was the shower bed and drain installation done wrong? How can I check this? My home is a five year old condo and part of many others like it.
Replies to this post
There are none.
