| Posted by nicktheplumber on January 14, 2003 at 00:22:34: | |
| In response to Re: Hot water distribution problem | |
You will need to install a water heater in the other unit to provide hot water to that unit. This will require some plumbing rearrangements. If you are lucky, the other unit will have an ample garage, crawlspace, or best of all a basement, where this work can be done easily. As hj says, your arrangement was never considered acceptable, at least not in the 30 years I've been plumbing. One thing I would worry about, and you didn't mention it, is this: does the other unit have its own municipal water supply (i.e. a separate meter)? If it doesn't, you have a really expensive problem to fix. : Hello,
| There are none. |
