| Posted by hj on January 13, 2003 at 23:31:50: | |
| In response to Re: Water pressure regulator question | |
The regulator is "slipping". : I have 120 psi coming in from the city's water system. I have a regulator on the main line set to 65 psi. I put a gauge inside the house and found the static pressure is 120 psi but when you turn on a faucet the pressure drops to 65 psi. Is this normal or is the regulator messed up?
