Re: Should Water Inlet Valve Be Left On All the Time?
Posted by hj on January 13, 2003 at 23:30:53:
In response to Re: Should Water Inlet Valve Be Left On All the Time?
Yes, otherwise, how will the boiler automatic feeder, (reducing valve), be able to add water if it is necessary.
: My hot water boiler has a Pressure Reducing Valve (as well as a Relief Valve). Should the water inlet valve remain turned on all the time or only when you fill the system?
Replies to this post
There are none.
